TwinTurbo.NET: Nissan 300ZX forum - low on brake fluid. :) (n/m)
zfreak(Dallas)
on September 16, 2008 at 10:54 PM
Here's my work in progress....
posted by 1badz32 (MN)
on September 16, 2008 at 11:20 AM
LitlElvis Top-feed fuel rail question
toykoz32
03:50:48 09/16/08
In order to put fuel rails above the intake manifold,
1badz32 (MN)
05:04:05 09/16/08
Re: In order to put fuel rails above the intake manifold,
toykoz32
05:43:28 09/16/08
You mean high and low impedance??
1badz32 (MN)
05:49:26 09/16/08
Yes . . sorry about that its late, and im at work (n/m)
toykoz32
06:37:22 09/16/08
using resistors on low impedance (peak and hold) injectors
LitlElvis
07:02:09 09/16/08
Resistors work just fine.
1badz32 (MN)
07:39:45 09/16/08
I agree, resistors will allow the P&H injectors to work
LitlElvis
08:11:32 09/16/08
2nd'ed. (n/m)
AntiHero
08:03:55 09/16/08
Simple question. The kit will clear both style plenums
Milo (SATX)
11:00:53 09/16/08
Yes my rails can use either plenum, but
LitlElvis
12:56:25 09/16/08
Lower pleunum - must be of similar vintage as the heads
15:59:11 09/16/08
You seem to be the "parts master"....
1badz32 (MN)
16:12:15 09/16/08
Post '93 - its from when the castings changed to support
16:25:47 09/16/08
So that will only be there on mani's from the J30's VG's??
1badz32 (MN)
16:36:09 09/16/08
No. (n/m)
17:01:51 09/16/08
Awsome, thanks dood.
1badz32 (MN)
15:33:40 09/17/08
Re: using resistors on low impedance (peak and hold) injectors
ouikikazz
11:40:57 09/16/08
No pictures in the car yet, but here are some with
LitlElvis
15:04:43 09/16/08
Re: No pictures in the car yet, but here are some with
ouikikazz
16:18:44 09/16/08
You dont need a fuel pressure dampener. (n/m)
1badz32 (MN)
16:23:11 09/16/08
Ask ye questions and ye shall have answers...
LitlElvis
21:23:30 09/16/08
Yes, the idle air inlets to the crossover tube need to be
LitlElvis
06:43:25 09/16/08
1badz32 (MN)
11:20:05 09/16/08
Can you sell me a setup for my 96 TT?
trbospd
12:42:45 09/16/08
I'm in the process of getting the "kit" ready,
1badz32 (MN)
13:15:05 09/16/08
I'll send you mine if you can make me a sweet development
trbospd
14:28:52 09/16/08
Let me get a couple of setup's made first, then we can talk.
1badz32 (MN)
15:47:17 09/16/08
so many things in that engine bay make me go "wtf!?" (n/m)
AntiHero
15:09:17 09/16/08
Thanks! (n/m)
1badz32 (MN)
15:36:33 09/16/08
How are your fuel lines ran?
na300zx (OH)
15:18:17 09/16/08
The fuel just flow's through the regualtor,
1badz32 (MN)
15:30:58 09/16/08
I'm loving the idea
na300zx (OH)
15:35:31 09/16/08
Many of the auto manufacturor's already use it.
1badz32 (MN)
15:46:05 09/16/08
So if I plug one end of my 300d rails and run
na300zx (OH)
15:49:38 09/16/08
Does the fuel flow past the injectors in those rails?
1badz32 (MN)
16:05:25 09/16/08
I believe the returnless have the regulator in the tank
AZHeat
00:15:07 09/17/08
An OEM returnless will have the regulator in the tank,
1badz32 (MN)
17:47:10 09/17/08
low on brake fluid. :) (n/m) -
zfreak(Dallas)
22:54:47 09/16/08
